LML Turbo Replacement
SheeB
51
Ottawa,Ontario,CANADA
Well my turbo is on the way out so a stock Garrett replacement is on the way.
What other parts should I have on hand for replacement? I have the oil intake hose and gaskets already.
Dozerboy
4,812
394
TX of course
Are you just wanting to make sure you have what you need for the swap or did you have other stuff in mind like a EGR delete?
SheeB
51
Sorry, yes I want to make sure I have whatever parts are needed to put the new turbo in properly.
I have already done the egr delete kit from Deviant, the LB7 uppipe, and a Flo Pro downpipe to the 5” exhaust.
Dozerboy
4,812
394
TX of course
As long as you have the oil line gaskets that's it. You should replace the small coolant hoses too. Atleast pressure tester system before buttoning everything up. It's not uncommon for them to leak aftwards. One of mine did and it sucked getting to it.
SheeB
51
I'm not sure how to get the picture attached for viewing in the thread, but I've attached it below.
So the dealer is awfully confused and ordered me parts for an LGH. :confused:
What part numbers am I needing specifically to get the new turbo installed properly? I was told by the Garrett dealer that I need to make sure to replace the turbo feed line and those gaskets for sure.
I'm thinking 1,2,3,5,6 at least. Do I need part 8 / 12 to reinstall that coolant line?
I can't recall what got deleted with the full egr kit, so I'm somewhat unsure as to what is missing. Lol.
SheeB
51
I had my pcv reroute hose freeze up solid and the turbo puked about a quart of visible oil out the exhaust. Now, 2 weeks later I am noticing when I turn off the truck it makes this growling noise which is easily heard with the hood open.
Dozerboy
4,812
394
TX of course
Hopefully someone will correct me if I'm wrong but all you need is 5 and 6. 2,3,8, and 12 only if you lose one I think they are all the same.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Dozer is correct.
You will also need the up-pipe gaskets.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I don’t reuse them on anything. They are cheap. Like $7-9 a piece. Is a leak and having to tear back into it worth saving $25? Not to me.
SheeB
51
Thanks for all those offering answers.
Is there a how-to online for this diy weekend project? Obviously having the egr deleted will make this a little easier and I was sure to anti seize paste everything I previously removed.
