Turbo question
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,505
33
LA
I need some help identifying a turbo as it's not what I thought it was.
The facts:
1. I purchased a used s475 MPI twin kit (not sure of age)
2. I know it is not a T6 96 1.32
3. I'm sure it is a T4 frame
4. 75mm compressor wheel
5. Spools incredibly quick for as low it is tuned
Corey
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
A full marmon exh flange on a t6 housing can be machined down to the style you have. Would make for easier downpipe configuration. (4") The flange is what you need to measure.
countrycorey
Jan 30, 2010
1,505
33
LA
I measured the flange when I had it out yesterday and it is a t4 flange (on the hot pipe).
Corey
countrycorey
Jan 30, 2010
1,505
33
LA
The cover was ground smooth and coated so there are no casting marks other than what is in the picture above.
Corey
countrycorey
Jan 30, 2010
1,505
33
LA
I cleaned it and looked, even tried to feel it and there was nothing there. Had a buddy sanity check me and he said the same thing.
Corey
countrycorey
Jan 30, 2010
1,505
33
LA
I'm not saying that it's not there, but if it is there, I could not feel or see it and I cleaned it and felt for it, I even looked with a flashlight with no luck.
Corey
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
That turbine looks like an 87mm though. It has the curved blades. The 83mm turbine has straight blades. That turbo is setup to be ran as a single.
countrycorey
Jan 30, 2010
1,505
33
LA
Thank you mike, all I know about it is it came with the MPI kit I bought off of a member here. He was told it was an s475 and that is what he told me. I ASSuMEd it was the standard s475 t6 1.32ar 96mm turbine. Boy was I wrong!
Anyone need a BNIB s475 t6 1.32ar 96mm turbine and a blanket from Levi?
Corey
countrycorey
Jan 30, 2010
1,505
33
LA
Update: I sent Mark Broviak an email including photos asking about this and this is his response:
Yes sir that kit is a GT4202 Garrett turbo. Great towing turbo kit! Let me know if you need anything else,
Corey
