Trying to find o ring part numbers - coolant leak
monster50iii
329
I'm trying to locate the correct oring for my coolant relocation fitting. The one behind the drivers side manifold. The guy at gm thought he found it, and said it was $32. I think he had the wrong one. Ive been searching now for 2 days and haven't found anything. Any help would be appreciated!
Ron Nielson
692
116
Berryton, KS
Get your vin# and then go to a GM Parts based website, input your VIN# instead of year, make, model, etc. This should get you only parts for your particular truck, options, etc.
Is 'coolant relocation fitting' a part that usually is present on LMM's? or is this some aftermarket part?
13,599
632
The only coolant o-ring I know of that is anywhere close to $32 is the one that goes on the metal pipe between the water pump and the oil cooler.
