LMM: truck is running now, Got a few codes help please...
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
P268C
P268D
P268E
P268F
P2690
P2691
P2692
P2693
P0113
P0098
P2033
P2455
P0546
:D
New motor, Dual Fuelers, 40% honed injectors, VVT Turbo, no DPF
Oh yea EGR is blocked.
I am using PPEs tuneer for break-in and to get it started.
Thanks.
jrkrace
269
Connecticut
I had the 268 code. turned out than the ECM has to sync up with the injector controller (?) I think. I had this come up when I used the ECM out of another truck that I had tuned.
EFI supposedly is working on a patch.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
P268C
P268D
P268E
P268F
P2690
P2691
P2692
P2693
P0113
P0098
P2033
P2455
P0546
:D
Thanks.
Nice! You got the cheetah on? VVT turbo?? Get me some pics!
LBZrcks
Jun 2, 2007
5,297
12
SoCal
If you have a Tech II you can copy over the injector flow rates from the GPM to the ECM. Are you using the GPM out of the new engine?
slowlmm
Mar 2, 2008
2,582
45
so cal
call me later mike ill will drop offf tht other ecm for you good point jason brought up are you using the gpcm out of the new or old engine i would use the old one
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
Also why not just use efi for the tunes? Instead of the PPE
Yea I just made a tune from the stock tune with efi, gonna load it in and see if things look cherry.
PPE was the only tune I had that was close to stock with the DPF delete so i used it for the time being.
also I was thinking its the use of the bigger injectors causing the codes....
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
The prob deff has something to do with the injectors/nozzles. Atleast in that area for sure. Pics?? Hows it feel? Good job Chad, you guys slapped that puppy in!
