Truck dies at red light
Porter44
Jan 30, 2019
Hello, I'm a first time user so I may be in the wrong area I'm not sure? My truck is a 2013 GMC with about 235000 miles , has a tune and delete done . I drive about 60000 miles a year .I do most of the service my self but maybe not this problem. I was driving on interstate truck started falling off and on like it was running out of gas took exit and it died at light. Replace fuel filter came up ,does that sound like the c3 pump and are all deaths castrophic or can I maybe replace just the pump . Thanks for any help
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
Could be a leak in the system and sucking air. Check the fuel filter, make sure its tight. Check the filter housing, lines, etc. You can press the primer bulb a couple of times and see if it hold prime or a leak downstream shows up. The primer bulb should be firm when working properly.
If all that checks out fine, very well could be a failed CP4.
Sent from my SM-G930V using Tapatalk
remisdad2014
Feedah!
Oct 4, 2018
11
Maine
When was the last fuel filter change? could have some stuff plugging it up causing a restriction. Are you in cold weather climate?
