I'm putting a 4bt Cummins and an Allison 1000 transmission in my Chevy S-10.LMM and up has the aluminum cased ones that are more durable then the earlier models. I think the internals are the same through. Not sure about the L5P with it's different transmission
What's the application or use that makes you seak out the "best"
No, I'm keeping it IFS.Probably going straight axle then? I’d go a ford 273 case then. Bigger tcase, stronger and fixed yoke at both ends
I going to beef up the front suspension.You're worried about a transfer case, and you're planning to run the stock IFS on an S10 with a Cummins on top of it?
Will they bolt-up to an Allison 1000 transmissionThe factory transfercase is quite stout, are you having issues breaking them?
Yes. That's what is meant by a "factory" transfer caseWill they bolt-up to an Allison 1000 transmission
