Transfer case MT24247209 60MT N902510874
peaceofwork
Dec 31, 2022
I got a transfer case thats 2009 Electric shift, my trucks a manual shift tcase 2008 can it easily be converted to manual ?
Or any reason to keep it around when my trucks a 2008 manual shift?
how can I be sure if it’s 3/4 ton or 1 ton?
1,610
Moved to TC/Axles section.
Is there a round metal ~1-1/2" tag somewhere on the case? That usually has the case type and number stamped on it.
1,755
I thought the transfer cases were the same for "manual" and electric. The so called "manual" ones for those years are actually still electric. Just a lever that actuates switches and the transfer case still runs electric.
But as Tom said you can take a look at your tag and compare it to that one and see if they are the same
gmduramax
Shits broke
Jun 12, 2008
4,045
226
Nor cal
Wasn’t it the diff is still electric but the T case was manual?
Dallas S
485
33
Alberta
The tags stopped when the magna corp took over tcase production.
The front diffs are electronically actuated. The tcase are either electric shift or manual. The electric t case use a transfer case control module(TCCM) to engage the front axle. The manual t case use a basic switch on the tcase to handle the front diff. Long story short.
Dallas S
485
33
Alberta
The internals are all the same. But it’s not a commons weak point/wear item. Probably not worth keeping around unless space is not an issue
peaceofwork
Dec 31, 2022
38x45 shops pretty full now days , it’s a constant effort not to collect shit I don’t need. And of course the guys that just want to leave something their for a few days… I give them a recomendatoon to the ustoreit- first moth is free
