Currently i have a zone 5' lift on my 2018 gmc 2500HD L5P. I am running 37x13.50s on 22x12s with a 4" rear block. With a new addition to the family i am looking to lower the lift down as close to stock rear/leveled height as possible. To do this i am told i will need to run 33x12.50s to keep my 22x12s on the truck. My main concern is should i be worried about towing capabilities with that setup? the tires i would most likely get would be toyo at2s (114Q F2). Is anyone running a similar setup that can provide some pictures/insight? or how close to stock height can i get and be able to run 325/50r22x12? I have an aftermarket front bumper so is should be good there and i have also already done a norcal mod on the cab side when i installed the 37s. Any insight is appreciated.
Edit - The heaviest thing i will be pulling on a regular basis will be my bumper pull camper which is around 10 maybe 12k at the most loaded. My main concern is if out of the blue i need to hookup to a gooseneck and haul one of my ford driving buddies truck home from the side of the road that i will safely be able to do so.
