towing 5th wheel weight
b.d.keathley
118
Des Arc Ar
Just had a curt 20k 5th whl installed. They only put 1 bolt in the frame each bracket. Doesnt seem strong so im having it welded. Im picking up our 2013 keystone cougar 333mks saturday. Trailer weighs 10000 dry am I still okay on pulling it. Btw had the neens install tune on the 6.6 and feels really responsive.
Taylor-34
Jan 13, 2014
443
Cali..
Had the 25k husky slider out in my truck and they only put 1 3/4" grade 8 bolt in the rear of the bracket and 1 5/8" grade 8 bolt in the front of the bracket, tripped me out but I have pulled my 39' gearbox around plenty of times with no problems.. Guess it's all ergonomics nowadays...
Taylor-34
Jan 13, 2014
443
Cali..
^^ right and
My hitch is rated 25k two bolts through the frame per side (2 on passengers and 2 on drivers) my trailer weight is 16k empty do I'm prolly pulling around 18k with the sideXside food fresh water yada yada
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
DO NOT weld to your frame. Drill more holes and add bolts. The camper place that did my old one only put 4 bolts in. I ended up adding 4 more for piece pf mind. On my Lmm I got the Reese not drill brackets. They work well.
b.d.keathley
118
Des Arc Ar
GCWR should be 22,000...So max trailer weight is 22,000 minus whatever your truck weighs...
how are those transport trucks pulling like 6 cars and a large trailer? Did they soop the motor or reinforce the frame in order to do that? By the way I broke my finger putting the egr block off plate in hahaha.
b.d.keathley
118
Des Arc Ar
Picking up the 5er tomorrow. Anyone know if I leave the tow/haul on and the od/off when pulling at 60mph? Dont want to burn up the trans
