Torsion Bars
baggedLB7
Goer
May 1, 2011
688
Utah
Well I'm looking for new torsion bars. My driver sided is sagged out and the sticker with the code on it is no longer there on either one. I did some looking online and found multiple part numbers depending on were I was looking. Can anyone point me in the right direction on which of these part numbers would be right for my truck or let me know were I could find a more info on how to find the right ones.
Below is some post from another thread.
There should be a paper tag on the bar with a two letter code. Here's a list of the codes and associated part numbers with their torque (weight) rating.
CHEVY TORSION BAR CODES AND RATINGS:
15048307-LH (code XK) (Max torque 4553)
15048308-RH (code XK) (Max torque 4553)
15048309-LH (code XL) (Max torque 4626)
15048310-RH (code XL) (Max torque 4626)
15712407-LH (code WX) (Max torque 4863)
15712408-RH (code WX) (Max torque 4863)
15048311-LH (code XM) (Max torque 5638)
15048312-RH (code XM) (Max torque 5638)
15528955-LH (code GF) (Max torque 5826)
15528956-RH (code GF) (Max torque 5826)
15058267-LH (code YH) (Max torque 5913)
15058268-RH (code YH) (Max torque 5913)
15712409-LH (code WY) (Max torque 5913)
15712410-RH (code WY) (Max torque 5913)
15528957-LH (code GG) (Max torque 6707)
15528958-RH (code GG) (Max torque 6707)
15528959-LH (code GH) (Max torque 7161)
15528960-RH (code GH) (Max torque 7161)
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15528963-LH (code GK) (Max torque 8615)
15528964-RH (code GK) (Max torque 8615)
15528965-LH (code GL) (Max torque 8782)
15528966-RH (code GL) (Max torque 8782)
15732338-LH (code XG) (Max torque 9054)
15732339-RH (code XG) (Max torque 9054)
Well I think i found my answer, if you click on other suspension parts in gm parts direct i can see the 1Ton torsion bar for the 3500 which is this guy
So i guess i definately bought the wrong torsion bar!:mad:
Manufacturer: GM
Part Number: 19330060
Part: TORSION BAR, LEFT
Part Notes: 4WD, 1 TON
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
GL bar is the most common on the 2500 and 3500 trucks, a guy on Dieselplace installed some XG's years ago and it was a pretty rough ride. The XG's were used on some 1 ton's with the snow plow package and cab chassis trucks. Call the dealer with your VIN to be sure, the keys are different from XG to GL IIRC.???.
A company called sway-away has some aftermarket bars but the cost was about $1190.00 per pair. The indexing was a splined setup giving you greater adjustability. I'll look for the company information in some emails I have..
Found it, the email is from 2014.
We have a set of these torsion bars that we can ship in a week. These torsion bars have a 2" splined end on one end and we include new 2" splined keys.
The set with keys goes for $1,190.00 per set.
Eric Andres
818.700.9712, ext. 230
Eric Andres <[email protected]>
baggedLB7
Goer
May 1, 2011
688
Utah
Thanks for the reply. Deff not needing the high dollar aftermarket ones for mine. Looks like the
part numbers have been replaced with
19330060-LH
19330059-RH
Im going to try one more dealer but the last two I have called could not help me. I might just have to roll the dice and order the GLs.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
I have a set of a 02' Chevy LT 2500 HD, had 114k on them. Tried them on my LLY to see if mine were junk but they both sat 1/4" from the a arm stop. Been in my garage painted grey for the last 5 years.
Make an offer of your interested, I don't need them, I use them for lifting from time to time.
I have a lot of parts I've had for several years I need to sell or trash.
4,952
19330060-LH
19330059-RH
What's the current ride height on your truck from stock. If your buying both, I can tell ya what ones would be a good place to be at
baggedLB7
Goer
May 1, 2011
688
Utah
Thanks for the offer but I will be going with new.
James I'm running 6" arms up front and a four link and bags on the rear. The pass bolt is showing about an1.5" and the driver bolt is in all the way and I was planning on buying both.
Thanks for any help.
