Timing calculator v3
Black6spdZ
Aug 7, 2009
30
Resurrecting an old thread.. just wanted to get some feedback on my proposed timing split table
Chavez91
People Go Outside?
May 30, 2012
139
Heh. Wouldn't you like to know
Im not an excel expert by any means, but this is something that I threw together today using Josh H's calculator. Im sure it could use a BUNCH of improvement, but this is just what i have. Hope it helps some
Its a basic timing calc for the LML. Should make things a little bit easier. lol Maybe Josh or someone can fix any problems with it, if there may be any. :thumb:
View attachment TimingCalcV4.zip
  • TimingCalcV4.zip
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
I assume these errors are because I dont haev Excel? and just trying to use microsoft works spreadsheet
1,755
Here is a excel calculator I made to get my LB7 to shift good. I haven't used it on any other trucks so let me know if it works for you.
i have another for the LLY that i will have to dig out and post up
  • LB7 Defuel Shift Calculator.zip
1,755
here is the one for LLYs
  • LLY Defuel Shift Calculation.zip
Chavez91
People Go Outside?
May 30, 2012
139
2004LB7,
Not to nitpick. Found another error. On the LB7 & LLY in the Base Torque tab, you use the same cell that references the 90mm3 to also reference 100mm3. Fixing these small errors seems to actually make it work quite well. Ill double check to see if there were any others that I had found.
1,755
another good find
fixed "again" versions attached
Mods, feel free to remove or merge my posts with the attachments containing the errors
  • LB7 & LLY Defuel Calculators.zip
Tommyashley
Dec 19, 2018
17
How does it calculate or how do u calculate it with excel, or is the timing calculator just for u to plug in ur stock numbers and ur adjusted number and then run truck and see what u get afterwards and that tells u where u want to be for what u want
1,755
Here is some other calculators I have created with another member on here but haven't had anything to test them on. use at your own risk
The one I would most like feedback on is the defuel calculator for LB7 & LLYs. if anyone wants to try it out and give us your opinion I would appreciate it
  • Defuel, Pilot to US & Larger Injectors Calculators.zip
4,967
really.... i literally just took the limo over for storage yesterday.... i would have loved to try out the defuel calc then! :roflmao:
4,967
I thought we were always told to stay away from touching defuel
unless you know what you are playing with and understand the tables in great detail, its best to not mess with it. you can start killing the trans in a hurry if you just go shoving numbers in and testing it out in the truck.
WOT defuel is the one to really be careful on, part throttle is usually overly aggressive the moment you start adding in more power so there is room to mess with it IF you know what you are doing in there. small changes can make a BIG difference and you need to run the truck for a little while and log to see how it learns in.
