Probably something out of a half ton would work good
Just run it without springs!!! I hope to try this out this coming year just to see what it does. But should work without issue if the shocks are up to snuff.
But just get something soft. Look to see what the spring rate is on those springs and cut it in half.
hes got some toe issues IMOP. And that combined with a tacky track can make for a jumpy ride.
How much nitrogen pressure is he running in the shocks? Compression seems light in the shocks too but all this cant be adjsuted till the toe is fixed.
I thought a slight toe-in was needed to help with that. I would assume there is too much as well (such as would occur with a bent tie-rod).
What is the "recipe". Toe-in, nuetral toe, Toe-out, slight, major, etc.?
