Sucking air
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
Guys I'm about to go nuts two monthsnow with this thing doing this and it is still dying after losing prime.
This is an updated list of everything that has been done:
The fuel lines running from the filter base to the FICM have been replaced.
The filter base is brand new.
They took a charge pump and connected it to the lines directly after the tank they put 160 pounds of pressure on the fuel all they found was the banjo bolt on top of the FICM was loose.
They tightened it down, kept it and drove it around for three days before calling me and saying it was done.
I went to pick it up drove it around for 45 minutes after going out for lunch we left the place pulled up to the red light and while sitting at the white line it died.
I got out cracked the bleeder screw and a small burst of air hissed out.
I tightened it down and began to pump it to get it started again and drove it straight back to my mechanics house.
I am about to pull my hair out what could be causing this?
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
The mechanic made mention of it today whenever I stopped by but I don't remember whether or not he said he thinks its that or he thought it was that and has already checked it.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
To see if it's the pick in the tank the tank would have to be dropped or the bed removed so did he check it? Putting a lift pump on it isn't a band aid IMO. It might also help diagnose
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Just curious, when you cracked the bleeder screw are you sure the hiss noise was air coming out versus being sucked in? Stock fuel system will have no pressure in there to push air out. Unless you primed it then cracked it open.
02greysixer
1,829
North Central FL
My money's on a pickup or hard plastic line issue. If your truck is a short bed with the standard 26 gallon tank it can easily be dropped by one person in no time.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
3,681
236
My 2003 has gone through a in-tank fuel pickup already. It had a small crack in the plastic flex line, and would start sucking air below 1/2 tank. Putting a lift pump on kind of fixed it, because it would return that bit of air to the tank. Eventually, the hole got too big, and I had to replace the pickup assembly.
Also: totally worth getting the new design assembly. I got mine on Amazon for $275. Not only did it fix the air leak, but it fixed the fuel gauge being jumpy, and the new one flows a LOT more than the old one. Still not as much as a draw straw, but probably 30-50% more than the 2003 model.
Finally, you might be surprised what is in the tank when you look. When I pulled the pickup out, I found a foam bottle seal from a additive bottle had fallen in, and was sucking up onto the bottom of my pickup. No wonder it only ran well when the tank was full...
Dirtymaxx03
3,110
Did you check all the lines from the tank to the filter head. There's a lotta fuel line to possibly sucking air, gotta check all of it.
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
Yes all the fuel lines from the tank to the filter housing were checked. The mechanic thinks that it is either an o-ring in one of the quick connects or it is the pick up in the tank.
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
It does it no matter what the fuel level is. Two weeks ago I stopped at a gas station and filled entirely up with fuel. As I pulled out of the gas station it died and I had to pull of the side of the ride and start it again. Once it started I took off it died literally 10 seconds after i put it into gear.
CaptPhil
1,012
Delaware
I like that theory more.
Collapsing fuel lines maybe? causing a vacuum in the system.
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
I'm starting to think the same thing honestly especially after having 160 pounds of pressure on the fuel I would think that any fuel leak at that point would have been extremely noticeable.
In theory how much money would it cost to replace the lines between the tank and the engine itself?
