There injectors are bigger?? Hmm maybe you need to do a lil more research.. Plus dont get so offensive. I just called you out because like i said ive seen you post in multiple threads bragging about how much better your tunes are then robs and that you can build tunes for anyone. Oh btw if your asking what tables to change for your rail pressure then why you offering people that you'll build tunes for them??, because obvisously if you really knew how to tune you wouldnt be asking all this shit. Good luck breaking into the low 12s manAre you serious?? Like I stated before do some research on me before opening your mouth. I've sent data logs and emailed rob multiple times, he told me i was maxed out and he couldn't do anything for me. My truck will run low 12's when I get my tire pressure and suspension set up. I've ran a 12.74 with a soft launch second time I tried my latest tune. I'm sure if I had more time at the track I would have already ran a low 12. Plus it's easier to get a Lbz or lmm closer to 12's because there rail pressure sees 26k and injectors are bigger than lly's. do some research and that might answer all your question before making yourself look dumb.
