Have 2004 lb7 that I just rebuilt the engine on and just installed. I power washed the engine after the install and drove it about 15 miles. Cleared old faults after the test drive and restarted a few times fine. 2 hours later went to start the truck and it will start and immediately die. No engine faults, building around 7000psi rail when it starts, truck has a Fass pump. I have checked the bale connectors and ficm connectors, unhooked batteries, nothing helps. Security light is on all the time, it was on before I pulled the engine. The bcm code is B2948 security system sensor circuit voltage high- from what I have read this will not keep it from starting. Any suggestions. Thanks
