Spring Clamps
moneypitt
MFNG
Jan 1, 2014
182
WA
I have searched but could not really find an answer. Is it best to clamp the front of the spring pack or the rear?
moneypitt
MFNG
Jan 1, 2014
182
WA
Ok thanks, I just installed Rancho 9000 shocks and made a set of spring clamps for racing on Saturday. Truck ran a 13.00 last time so I am shooting for 12's this trip.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
Houston, TX
For the track most just clamp the front. I ran it that way for a long time. You can go to a trailer shop and get a u-bolt and strap for cheap.
Some guys that are just making a quick trip to a stock class sled pull will use clamps on the front and rear from what I have read.
Dozerboy
4,812
394
TX of course
There really seems to be no difference. I tried both ways one day while playing at the beach.
IIRC the rear should be the best for controling hop.
Sent from a ditch being dug near you using Tapatalk
ryan415
Oct 24, 2012
371
860
I have had good luck with clamping just the rear. I do know for pulling though, you will want to clamp both the front and rear.
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
Front of mine are clamped. (2) pieces of 1.25 x .375 bar stock and (2) 7/16 bolts-nuts each side. I had hopping problems in deep snow alot. No more hop most times.
However, if you put it on a lift with the front clamps in place it will push your tailpipe WAY down.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
When I had them on my truck they would always slide in after awhile. First attempt to fix it I put rubber between the clamps and springs. Next and final solution I welded the bottom bar stock to the overload spring.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
How would that affect your tailpipe?
Dozerboy
4,812
394
TX of course
Madmax
That's funny my slide out IIRC but get hung up before coming all the way off.
Dozerboy
4,812
394
TX of course
It helps a little it don't stop anything. Kind of a wast, but their better then nothing.
