Some LBZ questions...
Mogman
341
17
Papalote, TX
This from the instructions for the BD High Idle kit. Shows the circuit only goes to the ECM.
They only ask you to set the Parking brake when using the feature for safety and not to depress the brake pedal. I am just guessing the signal cancels out the PTO function so its not active if you put it in gear.
Thanks, I understand that, I had read somewhere the parking brake must be set, there can be restrictions in programming that have nothing to do with the actual hardware, (an example is if there is a MIL light the truck will not remotely start or at least keep running even though the remote start circuit has nothing connected to the MIL) It could of course simply be that it is "suggested" that the parking brake be set and that got converted by someone into it "must" be set.
