small leak from bottom holes in bell housing...
dmaxx01
May 28, 2011
parkland florida
i just pulled and re installed my tranny due to a broken "flexplate"(or whatever you call the plate that attaches to the flywheel). i have noticed a drip or 2 a few times under the truck coming from the bottom holes in the bell housing. maybe its just some residual from the install. i sure hope so. any ideas on what could be leaking inside the bell housing?
blackdirtymax
Apr 15, 2010
825
augusta, ga
Did you take the bell housing off the trans at all , if not then I hope it's that as well . If you did take it off , you needed to put some sealant on the bolts that go into the pump
