Sas'd lmm
Forced lmm
May 14, 2016
17
Just figured I would post a few pictures of my truck since I'm new to the page. I've had a lot of questions from others so figured this would be a good place for q&a. Here is after I got it a few years back, I leveled it with 33" toyo mts on lml wheels. I also did the cab lights
Forced lmm
May 14, 2016
17
I used an 08 Superduty axle with wfo concepts trans cross member and 4 link. I didn't want the added cost of coil overs so I used factory ford buckets and springs instead. The springs are 4" skyjacker coils and they ride great. I did everything I could to keep it clean and simple to give it a "factory" look
Forced lmm
May 14, 2016
17
Thanks guys.
So from wfo I got
-cross member
-4 link
-drop pitman arm splined for gm box with ford drag link taper
-steering box brace
-track bar and engine cross over brace
-sway bar end links
Wfo has amazing products and there service is just as good
For the bolt pattern I had the front bearings re drilled to Chevy pattern since I had wheels. If I were to do it again I would of bought ford bolt patter wheels. The d60 is 3" wider then the stock AAM out back so I put spacers on it to match the track width. If I knew I was running soacers I would of just bought and adapter spacer.
Cost is hard to judge. I completely rebuild the exterior of the axle with all moog and ford unit bearings so it was not cheap. I would say I have $2k into rebuilding it and this is a cost that's not necessary I just wanted it to be new. All together I would say you could straight axle how I did for about $5-6k. That's doing all the work yourself and finding an axle at a reasonable price. I don't think this is bad because what do big fabtech, cst, or cognito kits go for??
The 33s was after I bought it. It now has 37s on 22x12s
Forced lmm
May 14, 2016
17
I spent the money on these dual stabilizers but ended up not running them. The steering setup puts a lot of stress on the stock box. It has no power at a stop but once rolling it's fine. As of now it has no stabilizer and still cruises the freeway great. I did buy a new psc box and ram to put on it just haven't found the time yet. Another thing I would do if I were to do it again would be a high steer knuckle to keep the drag link and track bar flatter. As of now they are running 12 degrees
Forced lmm
May 14, 2016
17
And here is a pic of how she sits. The front is on a 4" skyjacker lift spring and the rear of the truck has 7" of lift with block and add a leaf for now.
Forced lmm
May 14, 2016
17
Here's another from the front. Wasn't able to find matching diff covers so I ended up pulling this off and going with g2s front and rear
mackthehack
DUH...
Apr 16, 2007
831
Looks good. If you haven't done it yet. I'd recommend doing a steering box stabilizer or support.
blownblue
Oct 22, 2008
61
Acme, WA
Are you going to do a ram assist? Def takes some of the stress out of the frame/box
Just noticed your truck your from Washington what part?
