Here's the new rules they are purposing:
Turbocharger: The turbocharger is limited to a single small frame (s300 or gt30 series or hx40 or smaller) 2.5” inducer bore turbo. The bore will be checked with a 2.505" plug. The entire inducer portion of the compressor wheel must protrude into the inducer bore. No MWE groove larger than 0.200" is permitted. Any cutting, notching or etc. of the turbo wheels / blades will result in a disqualification. No bushing of the inducer is permitted. 6.4 liter Powerstroke engines may utilize the factory twin turbo configuration in OEM stock form only, no modifications allowed. No turbo exhaust foot larger than a T4 is permitted. Aftermarket exhaust manifolds are permitted as long as the exhaust flange is no larger than T4.
