LML s400/stock question
jckendr1
Feb 8, 2017
I have a 2011 dirtymax with just a mini maxx tune and dpf delete. everything else is still stock. its my daily driver and I pull a 30ft camper with it on weekends during the winter months...so basically it has no load behind it 98% of the year and I drive like grandpa ( never sees more than 2k rpm). If I put a compound turbo kit on there and ran my tune at the lowest setting wouldn't this make the truck still safe to drive power wise while making it a little more fuel efficient? I guess in my mind you would be getting more power from air rather than dumping a SL of fuel to it.
Awenta
4,090
CT
What's a dirtymax? We don't have those here
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
That's similar to what I built. Only real advantage is lower egt's while towing since you aren't looking for more power
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I think it's a special edition Duramax made for teenagers and flat billers. I'm just guessing though, I don't speak "Diesel gangsta"......
jckendr1
Feb 8, 2017
Lol well in my neck of the woods we don't have gangsters or flat bills and unless 31 is the new 17 I'm far from teenage :roflmao: but back to the topic at hand...I was just curious about a stock truck with a compound set up for lower egt's and possibly some better mileage. Just wondering what everyone else's opinion was.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Provided the tuning is setup correctly, yes, compound twins will improve almost every aspect of your trucks towing ability. I have a customer with an S475 over stock twin setup on an otherwise stock truck and he loves it. Says in his opinion there is absolutely no negative that he has seen, only improvements.
I'm not saying your H&S tuning is bad, (even though its junk) but whatever tuning your running, it will need to be changed to run a compound twin setup.
Awenta
4,090
CT
Start with an efi tune if you still want more then go with compounds and you'll already be set up to adjust the tune.
jckendr1
Feb 8, 2017
Yeah I've heard the efi is the way to go. Will probably make that switch soon. Thanks for the advice.
