Guys, a little history.
2001 LB7, new injectors, new head gaskets, new trans. Truck has ran flawlessly for several weeks. Blast to drive. Today while getting into I noticed a jerking/bumping in the engine immediately let out of it drove back home. Truck smokes white when you rev it, turbo doesn't even spool up, and has a bad shake at idle. No smoke while idling, only when revved. Popped off the oil cap, no crankcase pressure at all. I haven't checked the balancer, pulled on it for wiggle yet. But what am I looking at? Broke crank, busted piston, or hung injector? There are no codes, no SES, no knocking or noises. Just a bad miss.
Two weeks ago the truck did throw a large fuel leak detected code while horsing on it. Cleared that and never came back. I'm going to hook efi live to it tomorrow to check balance rates.
I'm really hoping this is just a hung injector!! At this point I'm tired of messing with this truck I just want it back running.
What do you guys think? Truck had 280k on it.
