Reduced Power
1,756
So I'm going to check continuity and output on the pigtail
Yes. You want to check resistance between the pins and that you only have power on the supply pin. Ground on the ground pin and nothing on the return signal pin. A short between two wires will show low resistance between two pins
Steve9
Apr 30, 2023
22
3
Florida
OK
Thanks for all the help
I checked the power pin on the plug-in. 5 volts
Ground was continuous with vehicle ground
of course sending pin on the plug was dead
Unhooked the connector and scanner threw a P0700 map pressure too low
So I put the old sensor back in and test drove-full power, no codes.
Amazon had many reviews of new sensors being bad, they will get one more.
I might put an o-ring where they old sensor sits on the intake, the rubber sealing piece is pretty compromised.
And I am keeping that "slope" scanner. It worked. Also my fuel gauge is now correct.
Gots my fingers crossed and thanks for all the help!
Reactions: 2004LB7
Bdsankey
3,914
1,074
Neenah, Wisconsin
OK
FYI, only buy GM sensors. No parts store brand, not amazon specials etc, stick to GM.
I've learned that lesson the hard way too many times which is why we will only use genuine GM sensors.
Reactions: 1FastBrick
Steve9
Apr 30, 2023
22
3
Florida
Yep
I got a Hitachi maf after reading they made the OEM ones. It was not cheap.
I am looking at a Delphi map sensor.
The original I put back in will only go South again I'm pretty sure That's GM, right? (Delphi)
Probably why the limp has been sporadic until last week
4,967
Codes? If it's going into reduced power there WILL be some sort of code.
LMM might actually code every time (not real confident in that) but a LML will go into reduced power / derate, throw a light, tell you you got 99 or 50 miles left till 4mph max speed AND have 0 codes. Literally just dealt with that this past week
Steve9
Apr 30, 2023
22
3
Florida
Yeh
I miss my '04 did the Banks six-shooter on it
no cat, dpf, muffler, phone, pool, pets
Sound was sooo cool, not real loud either
Oldest Son got back from Iraq in '08 so I had to get my LMM-he needed a truck. Kids...
Steve9
Apr 30, 2023
22
3
Florida
Really want to de-dpf the beast. Has the Banks 4" exhaust w/cat-muffler.
Need to research
Is it ok just to cap-off the egr, or much better to replace with a pipe?
Bdsankey
3,914
1,074
Neenah, Wisconsin
Yeah, I've seen it on LMLs where they'll derate etc and never throw a code but I have never seen that behavior from LMM. Every time I've had an LMM limp/derate it's thrown a code but I also certainly haven't seen it all tho.
Reactions: 2004LB7
