I'm probably going to answer my own question here, but I'd like some input.
I recently swapped my '04 2-piece driveshaft to the newer 1-piece aluminum shaft and 1480 series yoke. Per instructions, I counted the threads on the pinion nut before removing the old yoke and then I tightened the new pinion nut to the same depth. Now I have a pretty low level, but noticeable gear whine under decel. I'm thinking maybe I tightened the nut a little too much and that gave me some slop between the pinion and ring gears...maybe.
Could it be that the 1-piece aluminum shaft is just better at transferring a gear whine that's always been there?
The pinion gear is shimmed when setting backlash, correct?
Can I just loosen the pinion nut by 1/2 turn and test drive it, or will that even matter? If it's overtight the shims would have crushed some and won't go back to original depth, or will they?
It could probably use a freshening up anyway, but that's a cost I don't want to pay right now. Could it hurt anything to try loosening the pinion nut?
Thanks in advance!
Thanks in advance!
