Rear corner drip molding leaking
freeloader700
Sep 13, 2023
13
US
This little strip of trim or drip molding is causing a leak. How is this installed? Is it just glued/sealed into place? Can I just run a bead of silicone under it and squish it back down?
Sent from my SM-G965U using Tapatalk
815
The Moulding is double sided Tape and it might have 1 peg that it lines up on. The caulking is whats leaking.
I would pull the moulding up, strip the caulking, clean the rust and then seal the bare metal. After that you can install new seam sealer.
