question for the pros
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
Houston, TX
ok, I'm just curious on the overlap in the commands of the Allison. I know that on higher hp tunes (stock trans with transgo jr), the stock converter can have problems holding/locking up. Here's the question...if the converter is being commanded to lock, but doesn't lock, is there still a pressure drop to the clutch packs or is there only a pressure drop on successful lockup??
15,686
Pressure drop only occurs when the converter flow valve strokes. The pressure drop can be defeated with proper valve modification.
