Mike a read a post that you wrote in a forum a while back about vss wires. U stated that if these wires are not twisted every two inches then it can cause the 0055 code to pop. In your experience does this happen consistently with untwisted wires ? Or is it a hit and miss situation? And to add to that will this code cause the Allison to shift when it should not or cause a limp mode situation???
