I have a LLY that Im having problems with when it shift to OD. If you try and go WOT say 45-60 it will not kick down to 4th gear. Once under 45 it will down shift. You can lock out OD fine. I can also manually down shift into 3rd with no problem. I tried another stock tune from another LLY and it still does the same thing.
Truck has a new throttle pedal in it due to a mice nest in the fuse box but all wires have been repaired.
Could it be something internally in the trans that is not letting it down shift?. Truck has no codes or pending codes.
Thanks for any help
Thanks for any help
