Poverty awaits
ctodd36
101
Otego, NY
Taking the time to switch to 4.56 and installed a billet slider from DHD
ctodd36
101
Otego, NY
Does anybody know if these work with the oem fuel fittings that go to the feed and return?
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
What's everybody running for oil in these built motors?
We ran rotella non syn 15 40 in our wet block and now run Schaffers 20 50 semi syn in our new dry block. Bearings were always mint when checked in either motor. Thinking about switching to Valvoline VR1 50wt because it's cheaper and readily available.
ctodd36
101
Otego, NY
I believe that would probs my work. But you'd still have the short flexible piece the kinks shut. While your doing this much work I'd just run some an hose and be done with it.
I was planning on running push lok from my lift pump all the way to the hard line from the distribution block on the motor
Noreaster
2,910
42
Cape Cod,MA
I ran push lok from the lift pump to the cp3, run the ficm dry & stock filter housing has been gone for awhile
If I had dual cp3s I would run the hose to a distribution block from McMaster Carr, split the lines to each cp3 & put a pressure sensor on the block
I tried a different quick disconnect fitting for the return line from summit & it wouldn't fit the factory hardline
ctodd36
101
Otego, NY
Ficm has no issue being run dry? Awesome news!
ctodd36
101
Otego, NY
Been a while since I posted anything! I got the cab painted back to spiral grey metallic in the mean time. A mishimoto intercooler is in and a new fan set up!
