Possible head gasket failure?
Mr.T
Jun 15, 2012
96
Alright, so this is the 2nd time this has happened to me, once last year and once today, my wife started the pickup to let it warm up this morning and the low coolant light came on, there's absolutely zero smoke on startup and its not leaking, so where is my coolant going?
13,599
633
Check the upper radiator hose before you start the truck when the engine is cold. If it is hard, you probably have a head gasket problem.
BackNBlackTJ
Ahhh, yeah... about that!
Dec 22, 2009
66
Arid-zona
Is your bottle under a lot of pressure... mine seemed to pressurize the rezi bottle and push the fluid out when the HG went.
Which motor?
On my LB7 if the injector cups stick then it will slowly loose coolant and act like a small HG leak...
Been down this road, studs, quality gaskets, etc. are worth the coin...
Mr.T
Jun 15, 2012
96
My wife says the upper hose is pretty soft, reservoir bottle is not under pressure either, its an 02 lb7
BackNBlackTJ
Dec 22, 2009
66
Arid-zona
I take it you aren't home... otherwise I would say, pull a couple of the glowplugs to see if there is moisture in the cylinders... How handy is the wife, maybe she can pull them?
