So once I had seen the size of the ports on these Dmax heads I purchased to investigate. Being the operation range is very low, these engines need to breathe if I decide to go high flow breathing.
Here is my idea and I will post pictures of what I am going to change. I doing it just to do it and see what happens. I am sure everyone is aware of the basic smallblock chevy intake port, Even though the LML heads have slightly different port /runner configurations front to back of the engine, I and going to cut some intake ports out of a SBC and rotate it so the height of the runner is changed to a wider runner when installed into the Duramax head. I know there will be quite a bit of cut, fit, cut fit etc etc but I guess you could say building a port will help understand the induction flow itself. It should be a good learning experience, hopefully I can find a reputable flowbench once I am finished.
I will be measuring the current circle ports, hopefully get something to CC the ports too before I cut the runners off. Dimensions will come later since I have not measured them yet.
How high have the stock heads been operated at before? granted the heads I have are different from others, mine are from a 2011 engine and are iron.
