ok, i've got an 08 with mbrp 4", dpf delete, transgo jr, & edge race cts on lvl 1. everything was fine for the first 3500 miles or so, then bam, P0700. took it to the dealership the next day where they replaced the external filter and new fluid at my request. i did a trans relearn & drove off. let it shift at 1/4 throttle 5-6 times, then tried 1/2 throttle. bam again, only this time it added the P0777. took it back to the dealership & they think replacing the solenoid will fix the problem. did a little research on the internet and it seems 95% of the people having these problems all run the edge race evo, so i called them. of course they say it has nothing to do with their programmer. my question is, am i screwed & need to fork out several thousand $$$ for a built trans, or will a simple $100 solenoid make it by for a few thousand more miles? any help is greatly appreciated.
p.s. are there any decent shops in texas that you guys would trust to upgrade one of these trannys?
