P0700 limp code??
Aug 3, 2013
892
Arizona
Hey all, so I was just pulling out of my driveway, and the trans limped! How would this happen in 1st gear? The trans never slips and it's stock
Any suggestions??
4,907
need the codes...........
p0700 just means the TCM has told the ECM to flip the check engine light due to it having codes
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
If I remember correctly p0700 is kind of a general code for the trans you will need a good code reader V2 tech 2 or something to see what is actually the real problem in there.Search p0700 on here I believe Mike L has addressed that a few times.
13,597
628
I don't think the Edge will pull TCM codes, but it's been a while since I've messed with them. I could be wrong about that.
4,907
It says transmission control module tcm requested mil illumination..
I'm just confused at how it happened in 1st gear barely giving anything
smh... we know what the p0700 code means, we need to know the codes in the TCM that the scanner your using can NOT pull. without it, aint much we can do other than to take stabs in the dark.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
The transmission can go into limp for numerous reasons, not just clutch slipping, hence your reason for it setting slowly moving in first. Like mentioned already you need to get a professional scanner that can read the transmission control module codes.
