p0700 code
dmaxjoe
Dec 29, 2014
i have a 05 dmax it was crashd and i just got it back together but when i tryed to drive it is flashed shift range inhibited. it has the code p0700. in the crash the tcm was pulled unpluged anyone know what could be wrong?
15,686
Need codes. P0700 means nothing to us except the CEL came on. Get the codes read with a professional scanner and get back to us.
A. Stock Lbz
Aug 13, 2013
342
spokane wa
po700 is the tcm telling the ecm there is something wrong, you will need a scan tool that will read tcm codes to find the other codes. have you checked the trans fluid level and also if any of the tcm wiring to tell if they have been damaged?
edit: treed by mike
