P0606
9,903
149
What could a guy do to a tune to make it give you this code, put it in limp mode and the shut the truck down?
I have gotten this code probably 5 times and it is beginning to piss me off!:mad: Am I that bad at tuning?
The code is an internal processor error for pcm/tcm.
9,903
149
Alot of times related to the weather for that code. How cold is it up there? any moisture on or possibly in your ECM?
around 0*C when it has happened lately, but it has done it in the summer as well. It only happens after flashing in a select few tunes I have so I do not think it is moisture related.
It has NEVER done it with a Neens tune installed so I figure maybe I am just a tune butcher.:dontknow:
9,903
149
Interesting....... B1115 has values from 30 to 8 starting at 600rpm, B1116 has 0's in that same row. I will change B1115 to 0's and see what happens.
Thanks.
13,597
628
Why do you want to request a torque value at 0% throttle position?
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,149
Wilmington NC
www.mydieseladdiction.com
This is info that Ross needs to see. How did you figure this out?
First time I tuned an LBZ I had accidentally ended up with numbers above 0 in the 0% TPS row of B1115. Truck kept throwing P0606 codes and going into a wierd limp mode. Through trial and error we found it to be caused by the B1115 table having numbers above 0 in the top row.
racinmike77
Sep 14, 2008
1,029
MD
its because you guys smooth the tables, next time use the smoothing button that holds your max and min.
Nov 22, 2009
40
Queen Creek AZ
I thought I might hijack this thread instead of starting a new one.
Here are the details.
Last week I was hauling my dad’s bass boat (less than 3k) to Lake Powell for a fishing trip. Truck had a 50hp Tow tune that has been flawless for me.
Tow-haul on – cruise on – 55 mph headed down a decent grade – 5-6% - truck gets to about 60 mph and is just about to downshift into 4th – car in front of me decides to slam on the brakes – I hit my brakes at probably the same instant it tried to downshift – rpm went to idle – no hold back from the trans (like it was in neutral) – CEL – P0606 code – I turned the cruise off, tap shifted down to 4th and made it down the hill. Didn’t limp, cleared the code and it ran fine the rest of the trip.
I checked B1115 and B1116 like othrgrl suggested and they are all 0s.
Is this something I should worry about or did I just give the system to much to think about all at once?
