P0090 2007 LBZ. Won't clear even when engine not running.
Fmt2bx
Feb 28, 2024
3
PNW
Hi, new to the forum.
Spent a lot of time researching before posting. I have a P0090 (Fuel Pressure Regulator Control Circuit). I am using a Launch scan tool.
Upon getting DTC, the tool took me to the "live data" and everything there seems perfectly ok when I compare "desired" and "Actual" values.
I couldn't not delete the DTC with engine running or off. As the DTC specifies "Circuit issues", I unplugged and replug the FPR, move the harness around and was able to clear the code after that.
So, looks like it could be a bad wire buried in the harness somewhere.
Would anyone know or have access to a proper wiring harness schematic and could tell me what wires are used by the ECM to monitor a P0090 code?
Thank you
Ron Nielson
691
116
Berryton, KS
See the attachment and do the testing outlined as well as you can. What year and engine family do you have?
  • P0090.pdf
  • FPR Curcuit.pdf
  • Fuel Pressure Regulator (Diesel) connector.pdf
