Ok well removed alternator,ac compressor,intake,mouthpiece,tstat housing,coolant crossover pipe,t-stat piping to both heads,all the sensors and moved the wiring harness out of the way, removed fan,fan shroud,power steering pump/acc bracket out of the way and accessory bracket on left side with tensioner and two pulleys.... Only thing left is the Y pipe in the valley,and a hard fuel line going from what looks like the passenger side rail to driver side injector feed(4).. Do I need to remove the Y pipe to get the cp3 out? It's loose and you can see part of the gear when you wiggle it around. I just don't want to tear much more off to get this out.. Also seems like that hard line is a PITA to get to seeing how it's under the egr motor and other side going to the driver side...any tips would be great, thank you!!
