oil pressure test gauge
diesel on
Jul 16, 2016
19
Hi
I own an 05 2500 LLY and have a problem with oil pressure .I want to install a test gauge to monitor the problem and give me exact readings . Not sure where to plumb in . On the filter housing I see two hex key plugs . An aluminum plug 10mm hex above and forward of the filter , the other is smaller steel 8mm hex just bellow the filter where it screws on . the larger plug seems to be seized up but the smaller one is removable . does anyone know if this plug can be removed and install an oil pressure test gauge ?
Thank you for your time .
Steven Sabat
Awenta
4,090
CT
Do it with the engine hot. I just put an impact on it through the wheel well.
Both ports will work. One is pre cooler the other is post.
diesel on
Jul 16, 2016
19
I tried the impact gun with a warm engine . The hex key striped out and didn't budge . Is the smaller steel plug below the filter a choice ?
Awenta
4,090
CT
You have to clean the plug out and tap in the bit so it sits all the way down. Probably too late now.
That one will work too.
