No hiss at idle?
dwax
Jul 21, 2009
127
i dont know much about tuning, but i would like to take the "hiss" away at idle. i have a couple of tunes that sound this way and would like to do it with my race tunes! can anyone help me out. or should i call the one who made my tunes in the first place?
zfuller123
StarLite Diesel
Sep 2, 2006
429
Utah
www.starlitediesel.com
I'd call the one who made the tunes and have him adjust the vane positions in the idle RPM range. There are threads on this site about how to tune for the 'LB7 Rumble' - if you search for that i think you can find what you're looking for if you want to try it yourself, or to let your tuner know.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Go to tables b2214 and b2224 highlight all cells 0-15mm3 and 300-1000 rpm and set to 10.
That should take away the hiss at idle.
dwax
Jul 21, 2009
127
sorry it took so long, but i tried that and it still hisses until i put it into gear then the rpm drops and rumbles... any more help?
zfuller123
StarLite Diesel
Sep 2, 2006
429
Utah
can you log your truck at idle and post the log for us to look at?
Log RPM, Mainrate and mainrate2 (i think on lbz?), desired turbo boost position, desired turbo vane position, actual vane position, throttle position, actual boost and anything else you can think of that i'm missing related to turbo operation. Maybe coolant temp too...
Doesnt have to be a long log - probably 20 or 30 seconds and we could see whats going on and try to make some changes....
dwax
Jul 21, 2009
127
ok thanks alot. im out of town(away from my truck) but i will try as soon as i get back
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
That wasn't enough, need to go from 0-35mm and 0-800 rpm and use 20% to do away with the hiss, should only need to do it in the target tables only, no need in the max vane tables
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
I always do 10% at 0-15mm3 from 300 to 1000rpm in all the vain position tables. No issues to date.
See image and set like this in all Vain pos. tables.
attachment.php
You will get a position test once in awhile, are you talking about that?
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
If you can't figure it out post up the tune you want it on and I'll change it for you :hug:
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
lot of people dont like posting tunes they paid for, neither do the tuners that built the tune. Thats all I was getting at.
I assumed it was a relatively stock tune. I guess I skipped reading the part about it being for his race tunes.
Just trying to help him out
13,599
632
I've always done 0-30 mm3 and 0-1000 RPM set to 25% in tables B2210-B2215 and had excellent luck.
dwax
Jul 21, 2009
127
attachment.php
this worked great MMLMM... i just copied to the rest of the tables and now the hiss is completely gone! i also tried what JoshH said on another tune and it also makes a mean rumble!.. thanks for all the help!
mtl_dmax
Dec 7, 2010
114
Eastern Canada
I know this is an old thread but I can't figure out why you can only increase the target tables in each tune (A1114-A4114) and don't need to also increase the limit in the base tune (ie tables B2222-B2224)? I would have thought in that case that the base tune limits would restrict the target position but it seems not to. Does the minimum position table (B2225) also work the same way?
Can someone explain how these tables work together?
