Allison 5sp: No engagement
Dmax0389
Nov 23, 2013
11
This thread pertains to my truck a friend of mine and I are tryin to get to the bottom of this mystery. Manual valve pin along with everything in vb is in place. Starting to believe its either tcm/ecm or ignition switch?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
The allison WILL give you 3rd and reverse with NO electric input of any kind. If you have no forward or reverse with the main harness unplugged you have internal problems!! Period!
Sent from my SCH-I535 using Tapatalk 2
15,686
If he is unplugging the harness and it still won't give him any gears, (should give him 3rd and reverse) I don't care about limp mode or codes. He has a mechanical issue inside the trans. And since we know the pump is drawing and pumping fluid we can rule out a few things.
Best way to diagnose anything is start with the basics. No need to diagnose the electrical side of things until the trans will at least give him 3rd and reverse through hydraulic default.
Wrong. disconnecting main harness is anot a fool proof that you don't have an electrical problem. Go look at a wire diagram and you will see.
13,599
633
Mike, I don't think he's saying it means there is no electrical problem. I think what he's saying is regardless of any electrical problem, there should be reverse and 3rd if you unplug the harness at the back of the trans. If it doesn't, there is something mechanically wrong in the transmission. Is that not correct?
Evan@InglewoodTrans
yerp
3,118
65
Western MA
Dmax0389
Nov 23, 2013
11
Well I haven't had any previous problems with ecm/ tcm or
Ignition switch etc. I agree I should have reverse and 3rd. I'm thinking my next step is diagnosing with tech2..
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
That's exactly what I meant. Thanks for clearing that up Josh.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
The port on the bottom of the bellhousing right beside the spin on filter. It is a tap into mainline pressure. You said earlier you removed that, started truck and fluid gushed out. Is that correct?
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
Have you tried spinning the driveline by hand? A guy once brought me one he had assembled himself. In neutral if I grabbed the driveline I couldn't spin the shaft. He had clutches misaligned & binding up. When you put the extension housing or rear cover on the trans did it go together easy?
I only know the things I have seen myself. :)
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
That is correct btw the guy that has the one post it's his truck obvious dont check the forum to see any updates but all my info I get is from him txting it to me
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
Everything went to gether smooth and we where able to roll the truck in and out of the garage in neutral
Dmax0389
Nov 23, 2013
11
I currently have truck dropped off to a shop to run diagnose check. I will keep you posted as to what it comes out to.
