The truck was running and driving fine, no issues warning signs or codes. Parked it friday and sunday night went to move it and turned the key nothing happened. Dash lights up normally, shifted to N still nothing. The message center is saying service brakes, never seen that before. My edge insight isn't connecting to the truck. Friends snap on scanner couldn't connect to the truck. Checked all the fuses, swapped the started relay, nothing. Used the power probe to check starter and it will spin the motor over just fine when jumped. I also jumped the starter with the key in run position and it will not start. I found one thread about wires rubbing through under the fuse-box against the inner fender, but the pictures and harness looked different than what I saw in mine and there were no wires touching the inner fender.
