New VGT twins personal best on the engine dyno!
MarkBroviak
DMax Junkie
May 25, 2008
2,079
367
Danville Indiana
Did a little engine dyno tuning tonight for a street truck LMM with built motor and Danville 72mm Stg2R Vgt with BullseyePower NLX483 twins 200%inj and Dual fueled on fuel only! This is on 2100us at 22degrees max and was clean burning! Made 1217Hp 2283ftlbs at 78psi of boost. Very happy with the results to say the least and thought you guys would enjoy!
https://www.youtube.com/watch?v=_6cs1MPem4Y
https://www.youtube.com/watch?v=c9Yqt9ggPGo
1,650
Cmon Mark, you can do better than that.....it should run cleaner.
:roflmao: Nicely done. :)
3,688
244
That was an impressive pull! It cleaned right up, and didn't even smoke much getting on the turbos.
I sure wouldn't mind having a setup like that on my truck. Pity I can't run a VGT.
5,098
Really Mark, rub it in my face on FB. Now on here! my penny savings cant go fast enough for a new valley charger! :D
MarkBroviak
DMax Junkie
May 25, 2008
2,079
367
Danville Indiana
wow - very nice. What are the build specs if you can share
Thanks bud, it is SoCal Stg1 built motor that we pulled apart and oringed the block and upgraded to the 625+studs and SoCal 6480AF cam. 200%inj from Exergy and Dual fuelers. Has my newest 72mm Stg2R VGT in the valley with the new BullseyePower NLX ballbearing S483/96 1.32ar atmosphere turbo with the new Gen4 tuneable map cover which is cool. Customer wanted a fun reliable 1,000hp street truck so this is where we ended up with it. This power was produced on 2100us and 22degrees of timing max and made 78psi boost.:thumb:
This motor is going in an 08 LMM CCSB truck for a customer from out in the Virginia area.
Sorry Tom, I'll try harder next time sir!:D
moparkxracer
2,309
33
Out and about
Va area, wonder if I'll see him running around... Lol.
