Ghetto Waterworks:
This is homemade water cooling system for a 4 CPU high performance computer. It uses a Honda Del Sol car radiator, and garden fountain pumps.
This is about 47 sq in of radiator per CPU. SWTX Tyan S8812 mobo (4P G34) is in a Rosewill Blackhawk case with a subplate to raise mobo .125". Chinese water blocks are held down with homemade spring clamps. Red vinyl is hot, blue is cold. Radiator flows 700gph, CPU's flow 140gph each.
http://youtu.be/xtSGRYmH2Bs
http://youtu.be/Uu1OnOTJwwU
Running 41°C max at full load at 3.0ghz with 64 cores of AMD ES 6200 chips, Mobo using 855w + water and fans (all AC, not 12v).
