Need a stock file for 03 lb7 zf6 OS 15189044
H Hammett2121 New member Aug 19, 2017 4 0 0 Aug 27, 2017 #1 Need a stock file for 03 lb7 zf6 OS 15189044
hondarider552 Getting faster May 28, 2008 10,628 2 36 33 Arizona Aug 27, 2017 #2 Use the search feature on this site. They are here.
TheBac Why do I keep doing this? Staff member Apr 19, 2008 15,324 1,611 113 Mid Michigan Aug 27, 2017 #3 This should be it: http://www.duramaxdiesels.com/forum/showthread.php?t=11932 If its not, then look around the Tune Library here or at Diesel Place. Last edited: Aug 27, 2017
H Hammett2121 New member Aug 19, 2017 4 0 0 Aug 27, 2017 #4 I seen those. I assumed the "ALI" meant auto. Need one for a manual. Thanks
TheBac Why do I keep doing this? Staff member Apr 19, 2008 15,324 1,611 113 Mid Michigan Aug 27, 2017 #5 Im not sure there is one specifically for a ZF6. Might want to check the 2004 files, too.
H Hammett2121 New member Aug 19, 2017 4 0 0 Aug 27, 2017 #6 If the incorrect OS is loaded in will the ecm reject it? Or accept it and have problems?
C C.C.Reed New member May 1, 2008 91 0 0 Aug 27, 2017 #7 Here is an '04 15189044 ZF OS https://www.dropbox.com/sh/4ydh5wlt...STOCK/2004 LB7 15189044 ZF6 long bed.ctz?dl=0 Everyone should bookmark this link as it is the most complete EFILive tune repo around. Go search around to see if something fits your needs. https://www.dropbox.com/sh/4ydh5wltk3ssxbw/AAAOydqwo_stEO4Rs4SRJ9NGa?dl=0
TheBac Why do I keep doing this? Staff member Apr 19, 2008 15,324 1,611 113 Mid Michigan Aug 27, 2017 #10 Awesome! Thank you. :thumb: Moved this into the Tune Library for future reference.
