Need help with Trans problem
tractor
293
9
58
Spring Creek,NV
When my truck is at idle and in gear it fills like the converter is trying to lock,smokes and it wont power up when pushing on the throttle.
When you lety of the brake it will drive and power up and shift gears but seems like the converter is locked.
It is a 06 lbz and I read in the post eairlier that it was the converter.
I had the trans built 10 months ago with the gmax kit and A ml converter.
When I bought it I paid for the install to so I am not setup to pull the trans,so I wanted to know if it could be anything else before I either bought a trans jack or Paid someone to pull the trans and have it down while I have to send the converter in for repair.
Thanks Darryl
15,686
Talk to your trans builder. Not knowing what he did or how he did it leaves us at a loss. He should be able to figure it out.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Thanks mike I will try to get with him
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Daryle give me a call , if it is the converter its under a 2 year warranty , a few simple tests with the scan tool is all it will take to diagnose.
