Need Copy of LBZ stock tune
1,755
EfiLive may not be able to fix the areas of the tune that the edge modified. Often you have to do a full flash with a tech2 or take it to the dealership to have them do it. If you have the EfiLive license for your vehicle then it's worth a try
1,755
What I mean is the edge will modify some areas of the tune that EfiLive doesn't. So even a full flash with EfiLive may not restore the modified edge bits. EfiLive's "full" flash is not technically a full flash as a tech2 would do. That is the reason EfiLive can't flash in a new module. So if you are wanting to correct the checksum then you are probably going to have to use a tech2 or MDI
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
Well the fun has begun my check sum issue I guess was a from a lose obd2 port, got that sorted out and it seem to be staying connected. When to flash in the new tune and no tune made it to the ecu. Finally got the vin info back, but now getting p0602, controller not programmed. Not sure if I have harness issues, so I guess I am going to looking into making a bench harness. Not a great way to end the day.
Bdsankey
3,914
1,074
Neenah, Wisconsin
Push come to shove you can send it my way and I can bench it. I have a bench force and harnesses for 01-23 GM.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
Efi live will not flash back in the tune I pulled out but I found one that's supposed to be from a new ecu that I used to get the ecu to register properly, but am stuck with the p0602 code and no crank. Just my luck its just the OS. Would appreciate if anyone has a good know stock tune for a 2007 2500.
1,755
See here for stock tunes
Bdsankey
3,914
1,074
Neenah, Wisconsin
Message me your vin. I’ll check my tune library against what TIS2WEB says your VIN should have.
I have a pretty large list of stock files over the years.
815
Are you using the Opel tis2web link or is there a new gm nao one?
You have to go to AC Delco technical delivery system and create an account. Once you log in, under resources select SPS Calibration Information.
Put in a Vin and it will give you the calibration info you are looking for.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
That ended up working to get the truck back up and running. Thank you
Reactions: Bdsankey and TheBac
