I have been comparing my TCM tune with Josh's 6 speed TCM tune.
Under general parameters, I am missing some key functions his tune has.
please feel free to compare.
His OS is different than mine, but also allows adaptave learning for kickdown, and upshifting.
the main differences I am seeing is mine:
D1570 Mod main pressure Gsol enable low temp --- - MINE -10C ---- Josh= -10
D1780 Mod main pressure Gsol disable low temp ---- MINE 45C ---- Josh= -15
D1581 Mod main pressure Gsol disable high temp ---- MINE -15C -----Josh= 150
D1582 Mod main pressure Gsol enable low temp ---- MINE 43C ---- Josh= 145
also his upshift adapts are enabled, that option not even listed in mine
his kickdown adapts also enabled, no option for me again.
My trans does not seem to be learning either.
I would also note my TCM locked counter is zero, compared to his 254
I took it to the dealer, and since they count the flashes, they would not do it, as their records show it has the latest updates.....
Please help me to understand why my TCM is configured so different.
just the solenoid temp settings seem backwards, the numbers for min and max are inverted for mine aren't they?
Now how do I convince GM my OS is fubarred without admitting I have used EFI live to pull and check my calibrations?
If they would fix my TCM, I would never ask for transmission warantee again.
My plan is to instal a built trans, but the TCM obviously must be right first.
Please help me understand what is wrong, right or different here.
I need a good TCM and OS!
Thanks for any help.
