Dunno.
I know that air always travel from high pressure to low pressure. I know that the reason for the groove is to allow air to escape. And when you look at maps where the mwe is an option, there is a slight drop in efficiency and pressure ratio.
If you're going to run one, then put it as close to the tip as the rules allow, but if it's not in front of the tip, I can't see how a blade that is 90 deg to groove is going create a suction. Take a house fan, hold your hand to the side of it. Is it sucking air into the fan? Nope.
If the impeller is way bigger than it should be for the turbine, then it will show gains, but not because air is being drawn in. It will be because you can't drive the impeller fast enough, and the mwe will allow it to spin faster. If that's the case, the stock location would be fine. But the better fix would be a larger turbine.
