Mevotech Terrain Tough TTX ball joints
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Bought these on a whim after seeing someone like a simile proxy. T cheaper than Moog on rock auto so figured I’d give em a shot. About $32 I believe and lifetime warranty. Very well packaged and seemingly well built. Nice good and green color. Come with all hardware including a fancy cotter pin. The boot has a little weep hole for grease overflow instead of coming out the edges. We will see how they hold up. Pic dump below.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Summit_Rider
Jun 6, 2016
49
Yes I know. They could still pop out. Happened to a good friend of mine. A whimpy little snap ring is no match for the heavy front end of a duramax.
3,681
236
The upper ball joint doesn't carry any weight. The only time it is loaded is when the suspension is at full droop, and the load is pulling down at that point.
The only force pushing up on it is from friction in the UCA bushings, which should be well below what even a wimpy snap ring can handle.
Sent from my Cat S60 using Tapatalk
Summit_Rider
Jun 6, 2016
49
Gotcha. I did not know that. The passenger side upper on my friends did pop up though. Maybe he didn’t install them correctly?
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
I don’t think I’ll ever reuse my control arms more than thru one ball joint change for that reason. Seems to me the hole would get wallered out and make it easier for them to slide out
13,597
629
I never replace just the upper ball joint on these trucks; I replace the whole arm. It isn't much more money and, in my opinion, a little bit less work to change the whole upper control arm.
Hambone
Always learning
Jan 24, 2016
572
Florida
X2
The ease of changing is well worth the extra $$
And peace of mind because I also have had one wiggle out and had to fix before it completely dislodged
clrussell
pro-procrastinator
Sep 23, 2013
5,907
363
That’s what I’ve started doing. Entire moog upper control arms on Amazon are $60. 5 min change
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
And I just bought these exact ones. Sounds fishy tho.
Yeah I don’t believe that they’re bad. Maybe lowers and tie rods made them think they had play. If you’d like to use this thread to track your progress with them please feel free to. The more experience the better.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
I will be. They are the same joint that Kryptonite sells by the looks of it. With no fine print lifetime warranty.
https://dmaxstore.com/products/?route=product/product&path=206_55_428_437&product_id=1147
Same part number as on my box except mine don't say KR they say TKX.....
Good to know. I thought they looked similar. I’m very glad I didn’t pull the plug in Kryptonite stuff. I got mine from Rock Auto and I swear they also said lifetime but that’s always a crap shoot.
https://www.rockauto.com/genImages/143/Mevotech-Warranty_EN-ES-FR.pdf
