Help: MevoTech Reviews anybody?
TLKDRTYLLY
1833 AAV Crew Chief
Jun 9, 2013
189
Hampden, Maine
Anybody out there use MevoTech Lower Control Arm w/ ball joint assembly? What did you think? Brandon06Dmax and I are about to rebuild his front suspension, hes got bad pitman arm, bad idler arm, bad ball joints, bad bushings on his control arms, and a bad outer tie rod end, so he is just going to replace everything. Any opinions are appreciated. Thanks.
mreeves23
Big Hog Customs, LLC
Sep 15, 2011
91
Poseyville, IN
I would stick w/ gm or moog front end parts. I would look to add the Cognito Pitman Idler support kit once you replace arms too. Personally I only use, install, and sell gm, ac delco, or moog. Other than energy suspension sometimes for bushings.
